m67tang
Wish I had seen that first. Especially Since it’s gonna sit anyway.
They don't wait until single digits to be tested. You check winter-necessary systems the same way you check your furnace -- BEFORE you need them the first time.It's a shame these issues wait until single digit temperatures to rear their head.
That's a very good point. I should adopt the proactive approach versus the damage control method I have now!They don't wait until single digits to be tested. You check winter-necessary systems the same way you check your furnace -- BEFORE you need them the first time.
So, the small rings go to the small terminals, and the large go to the large terminals. And that’s all there is to it. No polarity needed?S and I terminals refer to a starter relay, specifically for a gasser. The Stancor and Western Plow relays (and any generic GP relay, for that matter) consists simply of two circuits, the coil circuit which is the two small terminals, and the contact circuit which is the two large terminals. Neither circuit is polarized in the relay, so you don't need to worry about which small terminal is which, or which large terminal is which. As long as you connect the terminals the same way as with the original relay, you're good to go.
That's it.So, the small rings go to the small terminals, and the large go to the large terminals. And that’s all there is to it. No polarity needed?
