bladerunner3
My '91F-250 IDI has always been hot in cab in summer. Would turn heater controls to "off" to not allow any air at all to come out of vents in summer but would still be hot in cab.(truck has no A/C so just roll down windows and go fast in summer. No problem in winter, have plenty of heat. Just re ently found that a mouse had chewed the white vacuum line going into the heater box. Thie point it is in two is on the left of engine compartment. The white vacuum line is a small diameter white tube, easily seen as it is on top of some other lines going into same same heater box. Has been that way for who knows how long. Truck has always seemed hot in cab sinch I have owned it, so maybe last 5 years. I have noticed that if I brake hard and then for some reason let up and brake again that I don't always have good boost. Give it a few se conds and the boost is there again.
So the pump is probably having a hard time staying ahead of demand with the small leak. Will try to fix this problem soon and give a report on whether it helped the brakes or not.
