Newbie needs help 1990 7.3 idi e4od
Fishermansteve
Liberty NC
I have a 1990 F250 with the 7.3 IDI E4OD Trans. Problem. ..no tach , only 2 gears, od light staying on ( dim ) speedometer intermediary acts up. I am totally new to Deisel engines . Only thing I have been able to check is the fuse under the dash. Where do I start ???
quickster
S Carolina
sounds like truck is in limp mode. try the tach sensor first. to the right of the oil fill. use the search here. this site can tell you everything. type in limp mode and see what you get. good luck
Larrymac
Staff online
