New to me 96 powerstroke
83ford
ford diesel baby
calico rock.arkansas.us
I'm changein the injector in the mornin since it came with 2 extras.it may not be anygood but maybe it'll get me a step in the right direction hes im putting fresh orings on it because I have some from our other powerstoke that we only did one side on.
Sent from my Iphone using Tapatalk
83ford
ford diesel baby
Ok so the injector I put in.worse then before so now idk what to do.knocking is still there kinda it's not as loud but idk.hell I may just have to run it and make it show up it runs fine but smokes like hell so any other things to check.and thank yall so much you don't know how much yall have helped me
ok, so youve changed injectors with one from the other 7,
did you read that this injector is different than the rest?
not saying this is your issue. but it could be.
when i was chasing a bad injector, i swapped the bad hole with a good one, this told me if it was indeed the injector or the harness.
i would highly suggest at this point to not only change the VCH, but to replace the pig tail thats going into the harness.
do not use dorman valve cover harness's they will get brittle and expose wire in a matter of months.
i would also swap to 99-03 valve cover harnesses if youre gonna do the pig tail.
1 connector is better than 2.
83ford
ford diesel baby
No i swapped it with one that came with the truck to see if the injector was the knocking issue or not.i haven't swapped the one that was missing which It wasn't this morning.after work im gone swap that injector back out and also pull the other vc.im gonna see if maybe somethin on that side is funky and causeing it.cause personaly I don't want to pull the motor I already gotta rebuild the trans cause reverse don't always want to go in
greenskeeper
PA
You have to run the truck hard to get the air out of the oil rails after r/r that injector.
83ford
ford diesel baby
Ok well I can't run it hard cause
that plug started smoking while it was running.ive already had one truck that burnt to the ground ain't lettin this one do it to lol.
83ford
ford diesel baby
Can Yall give me a link for the vc gasket and pigtails.i may actually have some cause they wouldn't work on our 94 pds.ill make sure there the sane
madpogue
Madison, WI USA
Plug? You mean the CONNECTOR to the UVCH? Or the (very sketchy looking) wire to the TERMINAL on the glow plug relay?
UVCH connectors are the same on a '94.5 and a '96. If you have some UVCH connectors, and they don't fit your '94, they're probably for an SD and won't fit your '96 either. Whatever you do, DON'T get DORMAN pigtails/connectors/gaskets. Several of the sponsors of the other forum sites (possibly this one too), such as RiffRaff Diesel, carry OEM solutions at a decent price.
(You have a _plug_ in the middle of your oil pan, and the bottom of your tranny, your radiator, etc. Those ^^^ are _connectors_. )
83ford
ford diesel baby
Thank you.i know they are connectors but I had about 2 hours of sleep so I was thinking that clear lol.and technically the 94 is a superduty just a fsuperduty lol.(just makin a joke not tryin to make anyone mad lol) once agian thank yall so much Yall are way more help to me then a lot of sites
madpogue
Madison, WI USA
Well you've identified a problem. May not be the main cause, but it might be. Definitely want to get that UVCH fixed, even if it's not the root cause, you want to be sure those are healty connections before you start trying to chase down anything else.
83ford
ford diesel baby
Ya im pullin that vc off tonight or tommrow and figure it out
madpogue
Madison, WI USA
^^^ Good move. If you're seeing electrical damage on the outside connector, there's a good chance there's damage inside as well.
83ford
ford diesel baby
No damage on the inside that I can see.i got it pulled and the wiring looked fine I'll look at it better in the mornin
fyi, if youre gonna swap injectors to see if this is your issue, you should swap it with one that you know for a fact, works.
listen to the previous posts, we are not ford certified mechanics, but we know first hand what does not work.
concentrate on your wiring before anything else like madpogue said.
more than likely this is your issue.
