New to me 96 powerstroke
Just the different pressures. Like at wot.
And yes, but you have to buy a Bluetooth adapter.
83ford
ford diesel baby
calico rock.arkansas.us
Ok I'll try and do that sometime this month lol.ive gotta get some money first.no one around here has a scanner that can do that I don't think.im gonna try replacing the cps and map sensor first because those were codes and see from there.
Sent from my Iphone using Tapatalk
Oh yeah.
Ford can do some of it. But of course better off getting your own stuff.
greenskeeper
PA
Sounds like it is running on less than 8 cylinders. You can pull the valve covers and look for oil to squirt out of the injector as it fires. No oil means the injector isn't delivering fuel.
There is a cheap way to "shim" the injectors if you don't want to invest in new ones.
As mentioned determining the HPOP numbers is helpful but I strongly believe it is an injector related problem.
83ford
ford diesel baby
Ya I do to now that I've seen it smoke like that.it just started to do I guess I ran it hard enought to make it show up.so I'll Probley end up checkin it out this weekend
83ford
ford diesel baby
Idk if that vid loaded or not it loaded on my other phone but the one I posted from still ain't showin it so im not sure but anyway as of now I'm changing steering columns so it's safe to drive.ill post the old one tommorow but I'm puttin one I got for 20 bucks at the salvage yard in it its for an auto but I pulled all that stuff off so after that im gonna get the cps put on.and go from there.do yall think it could just be the harness. The owner before the guy I got it off said it was but I'm not sure if I trust that or not.if it's injectors I'll probley just do them all.whats a good kinda cheep big set.like not cheep but not 3 grand lol.ill be Runnin the stock turbo for now intell I get to cut post the winter an stuff
Baby swamps are a fairly good deal. Or any of the big brand diesel shops have stockers. Actually talk to Mel, he does them also.
83ford
ford diesel baby
I'm really wantin baby swamps so that's probably what I'll get if I can afford to get a whole set
Yes, 160 cc I believe. Been awhile since I looked at any. When I do mine I'm skipping straight to hybrids.
