carid
Supporting Vendor
If you use your truck for work and often get to drive at night, having your truck's bed equipped with the additional lighting is a must. Our newest 8-Pod White LED Truck Bed Light kit by Lumen will provide you with the bright light output and illuminate even the most remote corners of your bed. The kit is pretty easy to install using the hardware included and usually takes less than 30 minutes to stick on. Each pod has 6 super-bright LEDs and comes with push-button on/off switch, which can be installed anywhere a 12 volt power source is located.
Looking for truck bed lights to get your pickup truck's bed lit-well? No matter the weather and time of day, bright Lumen truck bed light kit will provide you with powerful illumination.
Lumen® TRB-POD-BLK - 8-Pod LED Truck Bed Lights at CARiD
Go with Lumen automotive lighting, see the full range of products for your truck at CARiD.
https://www.carid.com/lumen/
