TeufelHundArms
I've been reading a lot on here, and decided an introduction might be in order. I'm new to IDIs and was looking for a cheap truck to play with. I ran across one I couldn't pass up, it's a 94 F-250 4x4 supercab, factory turbo IDI 7.3, E4OD, 4.10s. I drove 280 miles (one way) to pick it up, drove it 280 miles back home. It had a bad rear yoke, it shook the every living crap out of me. The yoke was bad, as the PO used the wrong u-joint.
I got it home, installed a new yoke, u joints, and center bearing, dropped the oil/sludge (It reverted back to crude I think), trans fluid, and Air, Fuel, trans and oil filers (I used the larger PS oil filter). I got the idle adjusted to where it should be (650-700 RPM in drive) (it was idling (warm) @ 1100 RPM).
The interior was, well not there. The PO has stripped the carpet and had an asphalt mat, W.T.F. over?!?! I stripped the interior, stripped and washed the floor pans. I then Line-x the interior, fully hushmated and layed new carpet. I still need the 4x4 shifter trim surround. The PO had hacked the wiring harness in the dash, and under the bed; so off to the U-Picked I went. The dash, cab and rear wiring harnesses are now replaced and everything works as it should.
She runs well, I've even driven her to work a few times(Ft. Meade, MD 250 mile round trip commute).
My plans are to:
1. Repair the AC (needs a new compressor for sure, and replace the dryer, condenser, and tube to be safe)
2. Banks 3" DP
3. Gauges (Pyro, Boost, trans temp)
4. 4" lift (all springs no blocks)
5. Extended S/S brake lines
6. 33" tires on stock Alcoas
7. Seats...Maybe re-do the stocks or ????
8. Replaced the bed
Look forward to learning more, and documenting my progress on the board!
My plans are to:
2. Banks 3" DP
8. Replaced the bed
We are a family bunch and look out for the well being of the members here. Hope you enjoy the ride here.
