never seen this before,....how bout you???
mojoman
Okanagan BC
hello folks...I have a starter prob
I have removed to 2 short bottom bolts and the top long bolt...the starter will wiggle but not drop out...I gave it some taps with a hammer...no-go...hooked it back up and turned the motor over a couple times...unbolt...no-go...still wiggles but hangs up...took dust cover from bottom of flywheel and looked inside..gear is stickin' out a bit...but at least 1/2 inch from flywheel....any help appreciated...
mojo '95 F250 4x4 7.3
94f450sd
somewhere,ma
just keep wiggling it.it will fall out but make sure your head aint under it.while its sota loose spray a good penetrating oil on it.its just a tight fit and a small amount of rust makes it worse.
geonc
SPIDER BAIT
NECKVILLE North Carolina
What he said...it's most likley hung on the adaptor---it's about 1" thick.
Road dust, clutch dust etc....will filter in the tiniest places!
BigRigTech
Diesel junky
Nova Scotia, Canada
Go ape on it and it will come out...Sometimes you need to put your purse and away and beat it with your hammer.;Poke:D:rotflmao...Just torturing the new guy...LOL
mojoman
Okanagan BC
thanks guys...when my eyes open up I'll put the panther-**** to it...appreciate the responses...:thumbsup::thumbsup:
mojo the hung over:puke:
mojoman
Okanagan BC
was a top bolt that hung me up...but there is no mount hole for it..:dunno
mojo old starter out new starter to go in....soon...:thumbsup:
Studebaker62
