need to flush rad system, Cascade detegent ?
Moretorque
Dunce
Florida
I need to flush my Rad system and read Cascade does a great job, that is dish detergent. What should I use and what kind of additive should I run in RAD to stop worm rote?
Thanks
I would not put any type of soap in there. I would drain the entire system. Drain the radiator and then pull the lower hose off. Get underneath and open up the two drains on either side of the block, and the one on the oil cooler. Then take one of the heater core hoses off the engine, stick a garden hose up in the hose and run water through the whole thing till everything runs clear. Then run water through the top of the radiator till it runs clear.
Then button everything back up, and then do a search on the different type of coolant, pick the way you want to go, and get the correct coolant or coolant + additive you want to run, and go by the grocery store and get a few of those large distilled water jugs. Don't use your house water supply to fill it back up, unless you have very good soft water. Most people do not have soft water in their house.
lotzagoodstuff
Carmel, IN
If you're really wanting a long lasting coolant system you should think about adding a coolant filter. I am looking into one for my new truck as it's really the only way to guarantee that you are catching any of the "funk" that can build up inside the cooling system. The coolant filter also gives you an opportunity to add your SCA's via a filter which seems pretty popular with IDI owners. I agree with the drain & flush per franklin2's instructions above, but I'd be sure to use distilled water and make certain you add SCAs and then keep an eye on the levels with the test strips.
A long lasting coolant system really makes these trucks last. Good luck to you.
lotzagoodstuff
Carmel, IN
If you choose to, keep in mind that 1) it might cause some stuff to leak like your water pump seals and 2) you gotta get it all out when you're done.
I've pulled radiators out and cleaned them with flush and/or muratic acid, I figure that way you aren't exposing the whole system to the acids in the cleaner, but keep in mind: your radiator is big/heavy/ugly.
Good luck and by the way, welcome to OB ;Sweet
Thanks
The only reason to DO a Cascade automatic dish washer detergent flush is when your oil cooler O rings fail :puke:and subsequently you get oil into your cooling system-cuss
The cascade helps to wash out the oil in the system and that's about it.
Why are you wanting to flush your rad? If it is a build up of calcium or other material remove the rad and take it to a rad shop for flushing, this makes sure you don't use chemicals in your engine.
I did a very aggressive flush on my truck which had sat for many years, then lost the water pump, then lost the rad most likely due to the removal of built up crud in the system. It just kept coming out dirty for several flushes, as many as 8-10 before I saw clean clean water.
As mentioned a coolant filter is your best friend to keeping the cooling system in tip top shape and making sure your SCA additive is at the correct level. Having a coolant filter you can get pre-treated filters with different amounts of DCA and change them out once a year or as needed based on coolant test results.
Hope that helps clarify thngs for you.
JM2CW
Al
As has been asked, Why are you thinking about a flush of the cooling system? Muratic acid is about the best but can be the most harsh on the system fluch you can use. Its great for removing the mineral drop out from the water that many owners have. the minerals plate the tubes in the top of the radiator and plug them up. This results from using well water or tap water that always heavy with minerals. Distilled water is what should be the only water in our cooling systems. It wont loose minerals and its non conductive too so no electralia will happen.
I took my original radiator to a local shop, and he would not clean it out. He showed me some small white fuzzy looking stuff around the bottom tubes right above the bottom tank, and said all that would probably leak if he dipped it to clean the radiator. That's when I bought the aluminum rad off ebay.
Moretorque
Dunce
Florida
I just want to flush the system good and get all rust out of RAD, what is the best additives to run with the antifreeze? Thanks for the help.
bneumann22
Staff online
