Need help on 7.3 IDI fuel filter please!
Gr8ful
Michigan
Bought a sweet '93 Ford ambulance with 88,000 miles. Drove it 200 miles home & about 50 local & bought fuel, then the fuel filter light came on so I bought a Wix 33617 which I guess is wrong. It's a Ford E-350 cutaway with a Horton body. It screws on like normal but has a bottom cap where I assume is the drain. Anyone know which filter I need? It was changed 3-15-15 written on the filter & written under the hood it says fuel heater changed 3-15-15. It doesn't have a fuel heater does it? That wasabout 8,000 miles ago. Any & all help will be appreciated, Thanks! Eric
Thewespaul
Bulverde, Texas
That filter will work fine. The fuel heater is the plug on top of the filter head
Gr8ful
Michigan
No but I think its a wix 33217, The parts srore told me wrong 33617 & couldn't figure it out. Thanks!
chillman88
Central NY
So it sounds like you are MISSING the bottom cap because someone installed a filter that doesn't use it correct? I think 33417 is the wix one you'll need. I'm running a baldwin bf1222 on my 91.
Kevo1288
Worcester MA
The 33617 should have the correct provisions for the sensor as well as a drain. Its the filter to go to!
William88
