Mysterious Starter Behavior
Tristan
Federal Way, WA
Did you adjust the new switch correctly? Make sure that the positions of the key correspond with the right spots on the switch. Try adjusting it up or down a little and see if it changes.
It literally has to be either the ignition switch half engaging, or a short in the wire to the starter relay on the fender
I feel like I have it adjusted correctly. The accessories position comes on correctly and it clicks into the on position in the right spot, just sometimes this includes the starter engaging. This leads me to think a wire is shorting. I will have to poke around and see what I can find. Maybe I could hook the trigger wire to the horn [emoji6]
Tristan
Federal Way, WA
Well I found a possible cause...
BrianX128
Pittsburgh
Wow. I wonder what happens if you stick all of those together and turn the key on? Haha.. at least you likely found the culprit.
Tristan
Federal Way, WA
It is one of the connectors under the brake booster. Not sure how the insulation on the wires disappeared but I am in the progress of heat shrinking them all. There is another connector under it that has three or four that are the same. Hope this fixes the starter issue. Seems like it may fix some other issues I don't know I have [emoji39]
Tristan
Federal Way, WA
All better now!
Started up normally and test drive went well. Going to drive it for a while and see how it goes [emoji1303]
Jason1377
Arkansas
Glade you issue is fixed and your gauge is working maybe more issueless days ahead
Big Bear
