My lovely e4od is still acting up
homelessduck
It acts the same when it is all hooked up. It seems as if the detent intside the trans. is off, even though it's a pretty basic design and I can't imagine how it could be off.. I have a junk e4od that I have been messing with , trying to figure out what could be messed up inside the pan, but the detent selector doesn't have any room for adjustment, and I can't find anything that could be causing this issue. It definitely feels like a mechanical issue though I am open to all suggestions. I have thought about swapping in another detent and selector tab but I really didn't want to have to buy more trans fluid.
trackspeeder
Stone crusher.
North Branford. CT
Drain the tranny fluid into a clean bucket. No need to waste it.
It might be time to take a look inside. Something funky is going on. You will want to check the detent spring. Take a good look at the detent itself. Post up what you find.
homelessduck
I've always been too scared about draining the trans. fluid and reusing it, even when it's new. I live in the mountains and have a long dusty road. We have a lot of dust in the air, and I don't have an enclosed shop. I may try it this time though and try to work fast before the dust gets on/in every thing.
I think pulling the pan is my only option at this point, it has to be an issue with the detent or spring. I'll pop it off and take a look :) . I did have to remove the detent spring and replace it, I had shifted it too far and the spring popped off the end of the detent arm. The gears clicked in really soft so while I had it off I bent it SLIGHTLY so that it would put more pressure on the detent and be a more secure fit. Maybe this is the issue... but I can't see it causing any problems as it was barely bent and it shouldn't change anything other than how firm it clicks in.
homelessduck
I pulled the trans. pan today. Check out the pics to see what I found LOL . I replaced it with a spare, tossed the pan back on, poured another 8 quarts into the pan and fired it up... IT WORKS!!!!! It's a lot smoother and does not rev as high to move. I am SOOO relieved !
Thanks for all of the help AGAIN guys!
OOPS, forgot the picture :)
