I have no idea what my package said. It was a long time ago. I do remember that all of those were included in mine. It is kind of funny since you pointed it all out.
I believe he bypassed the mechanical pump.Are you using the electric pump bypassing the mechanical pump, or is it in line with the mechanical pump?
Sent from my cp3705A using Tapatalk
There will actually be no progress today. Other work takes precedence.
Awesome thank you. I was afraid mine wasn't strong enough at 5-9psi. I am anxious to hear how that pre filter works. If it flows fast enough to keep up with demand on the road.I don't have a pressure gauge.
MFGR says 4 to 7 lbs pressure. 38 gallons per hour.
https://www.edelbrock.com/universal-micro-electric-fuel-pump-38-gph-144-lph-diesel-17302.html
I'll bet that you're right. Mine is similar to that one, BUT it is only used to fill a new fuel filter. Any other time, it's off and the mechanical pump draws fuel through it. I may damage the diaphram in the mechanical pump this way, but it takes less than a minute every couple of years or so. The chances are minimal. No, I don't put many miles on my truck. I doubt that I've put 5000 miles on it in the last year so the fuel filter doesn't get changed out very often.It will hate life trying to pull fuel that far.
It's a possibility.It will hate life trying to pull fuel that far.
This won't help with the cuts or sharp edges, but I do have some advice on how to make the line install a little bit easier. First install the bottom of the line into the fuel ump. Then put the upper nut back onto the fitting on the filter head. This won't make it an easy job, but will make it easier to do. If you put the top of the line on first, sometimes it's a "Mo Fo" To get the bottom lined up at the right angle to thread into the fuel pump. Another thing you can do is if you're having trouble sliding the line into the upper fitting, you can rotate the fitting slightly upward and then slip the line in the fitting and rotate the fitting back down and start the nut.Don't remove the steel pipe that goes up to the fuel filter, from the mechanical pump, until you are quite sure that you are removing the mechanical pump.
It is a bear to get back on, while the pump is still mounted to the engine. I mysteriously cut my arm in several places. Still can't find the sharp edges that must be there.
