Are the returns and feeds separate on the stock setup? Would it blend with the non wmo tank? Thanks guys -Chris[/QUOTE said:The stock 6 port switch/valve, the feed/supply and return flip at the same time, yes.
Reading Josh's comments about stock tanks brings a thought to mind.
IF you can start up and shutdown on wmo and not have to switch tanks, your clean diesel fuel will stay cleaner. DUH
The reason I bring that up, many times we talk about shutdowns on clean diesel. IF your pickup seems to start ok on wmo, and the temps aren't too cold, then you could keep the switching tanks down to a minimum.
I think it depends on your how each persons pickup "reacts" to wmo start ups.
