Mechanical injection pump on common rail 6.7 Cummins
lotzagoodstuff
Carmel, IN
Black dawg
USA
Mechanical is always cool to me, simpler and dont need big power anyway.
Be interesting to see what his fuel system + conversion gear case cost. Maybe that pump is capable of way more? 472 is on the small side for 1k.
Doubtful it was less than what it cost to do the same with hpcr. Cool though.
Black dawg
USA
Ok. I learned to read. The 82mm 472 is on the manifold. And a gt55 atmosphere. That is ready for some power
lotzagoodstuff
Carmel, IN
I appreciate all the cubic inch, stronger rods, and camshaft mods they did to support the four digit HP goal, I’m just wondering what they could do with a stock long block as it sounds like the pump is nearly bolt on, and the controller is relatively simple/cheap. Kind of a “the engine they should have built” kind of deal.
Black dawg
USA
Stock block will handle that power, but from what I understand, better rods are probably needed if you are really going to use that power often, and for longer durations. and commonrail is not hard to get to that point either.
bneumann22
