I may well be a 6.9 but see the "upgraded" filter head. Thats off a 7.3. It also does not have the bleeder return line on it either. Big mistake when changing a fuel filter. Without the bleeder all the trapped air must now go thru the injection pump. That takes more cranking and wears out the starters quicker. Then the injection pump gear cover is the 6.9 style and there is no tach sender but at least it has the location. Does that mean its a tach free truck.. Maybe but the only way to be sure what engine it is will be to clean off the drivers side top of the block. Thats the area just past the gear cover. The block serial numbers will say 6.9 or 7.3.. I'm guessing its a 6.9 but thats aswag at best from this side of the puter.
