Max boost before heads lift?
97idi
mt airy/maryland
ive been tossing around the idea of arp studs..then adding **** injection. only one of the good **** injection kits that injects fluid based on turbo pressure. i believe cheapet i have found is 500 and snow performance is close to 1k for a kit.. i will probably end up buying studs tomorrow because i need it.. ive even considered being a tester for the custom MLS gaskets...
here is a turbo calulator. www.turbofast.com.aus
also what type of bottoming tap do i need for head studs? whats the pitch/size?
i put a coolin mist setup on my truck i just bought the pump and nozzles/ fittings off ebay then got my own tank to use for like $240
noticeable power increase when tuned right ;Sweet
Big Bear
