I appreciate all of the help that everyone has been giving me with my E4OD troubles. But now I have found a super duty with the ZF5 in it and I am seriously thinking about buying it to do a conversion. I had the motor balanced when I built it. Will a shop be able to balance the new flywheel to the balance of my old flexplate? I currently am using the old heavy 6.9 flexplate. Thanks.
Honestly, you can use it without balancing - it'll work fine. But yes, I'd expect any shop that can balance something to be able to balance a flywheel to match another one. It shouldn't be off by much.
Many that have actually had them checked, balance was way off. Several even being drilled off center. Sent from my SM-G988U using Tapatalk
