The plan is for a waste oil burner people hauler/camper hauler. It will need a lot more work than I had planned. Aside from adding seats ( looking for a conversion van being scrapped ), and getting it running, ( inj pump) I'm looking at paint, front end work, ac repair and building the in cab who tank. Going to use the rear heater lines to heat the who or wvo and put the tank under the rear most seat/bed. This will help solve the coil oil issues I have had running who with my current truck.
I'm a bit concerned though, I pulled the dog house last nite, put it on charge and checked for fuel. It cranks like its missing a hole. I can hear compression passing through something. I hope its just a bad injector seal. The can of starting fluid in the drivers door pocket was not encouraging.
