DrCharles
When I added the factory turbo setup to my 7.3, I also converted the on-off oil pressure sender to a Duralast PS-4 (on the turbo), and jumpered out the resistor on the cluster. So I actually have a dash gauge that moves.
However, now that it's really hot, the oil pressure at idle (below 700 rpm) is so low that the sender opens completely and the gauge reads zero.
That means the pressure is only 4 psi or even less:
I guess the next step is to hook up a mechanical gauge and see what the actual psi is.
But what do I do after that, if it really IS low?
My old F150 with the 302 sludged up the pan pickup. Don't know if IDI's are known for this.
Dropping the pan on these is supposed to be really fun, and hard to get leak-proof afterwards.
That means the pressure is only 4 psi or even less:- 0-4 PSI - Open Ckt
- 4-8 PSI - 24-36 Ohms
- 90 PSI - 8.5-17.5 Ohms
