Shawn MacAnanny
Where you take pressure readings off the turbo supply line is what the mains are seeing. That line to the turbo is the same pressure as is the rest of the block. As for the 1/8 or 1/4 supply ports. They will both supply the same amount of oil to the turbo. The bearings in the turbo are a sleeve bushing type bearing. We do not have the needle or roller bearing type shaft. Banks found the 1/8 supply line gives plenty of oil to the turbo. Otherwise they would get plenty of warranty work... And they did not. So it works fine.
I disagree with this. This would only be true if the turbo bearing needed less than 1/3 the flow in the 1/8 supply line. While it will provide adequate flow for the turbo bearing being it's the last lubricated part and drains to a non pressured vessel there will be a pressure drop. If supplied with a 1/4" line, 4 times the volume, the bearing would have adequate flow plus extra oil flow to maintain that pressure. If you have a pressure gauge on a garden hose and a valve at the end, with the valve closed you'd see 50psi, open the valve slightly and you'll see it drop to maybe 48, open it all the way and it drops to zero because the supply flow can't keep up. The same pressure drop would be in the turbo oil supply block being retrictect by the 1/8 hole taking the oil pressure downstream of that reatriction.
