replace oil cooler header, or gamble on the spring mod.
i too had an issue with low oil pressure at hot idle.
it happened all of the sudden in my 87.
went from 20 @ hot idle, to 5 @ hot idle.
i thought my bearings **** the bed.
i rebuilt the entire engine.
bearings spec'd out perfect (w/ plastigauge)
i used the old oil cooler.
to my surprise, when i got it running and it got up to hot idle, oil pressure was at 5 psi @ 200*
shut it down and changed oil cooler, hoping for the best results.
i swapped it out, and now i have 17 psi @ 200*
there is a shim and spring mod we can do to these, but my inexperience said to just swap them for now.
i look forward to finding @
typ4 or @
icanfixall thread on how to do this.
i dont know if they exist, i havnt searched.
but i still have a header that has a *****'d bypass valve.
low pressure high volume for sure,
but i speculate the timeframe i had a lack of 15psi + oil pressure is the reAson i cracked a head
never mind the 1300 EGT's
