Low end torque capability of 7.3 idi vs p7100 cummins 5.9
Daniel McCurdy
Evarts KY
So witch engine has more capability of making the most torque below 1800rpm the 7.3idi or the 12v cummins. what if the 7.3 had a p7100 would it make the low end more capable.
Daniel McCurdy
Evarts KY
What is it a crazy question? I figured that the 7.3 has a very large displacement advantage witch helps low rpm torque but the cummins is a straight 6 witch naturally makes better torque. I'm not talking about stock engines. The 7.3 would have something like a rd4 150 pump and matching turbo
Philip1
Northeastern Nevada
I cant say much for modified, however stock the turbo 7.3 idi makes 388ft-lbs @ 1400rpm. The 12v cummins makes 400-440ft-lbs @ 1600 rpm (depending on year)
Iirc, lower rpm + more power = high cylinder pressure. The cummins will handle that better.
For either engine, a vgt style turbo will help. Dps turbonator would be my choice.
03wr250f
Hamilton/Montana
If your planning on a rd150 the motor will not like low rpm lugging
That pump is more geared toward high airflow from a turbo and stage 1 camshaft and that camshaft doesnt like to be below 1800. It is oriented much more towards high rpm
For low rpm it's going to be likely no bigger than a 90cc pump and a typ4 torque cam
Sent from my SM-A015V using Tapatalk
dever35
dayton tx
So I had a 24v cummins p pump to install in my 94 F 350 but the price tag kept getting deeping into my pockets before installing, always wondered how that would've worked in front of a ZF5
madmustang1965
