LMC headlight relay kit, replacement relays
Kevin 007
Full-floater
Nelson BC Canada
I recall reading some time ago about how LMC relay kits used a relay that isn't commonly found at a parts store. Has anyone come up with a modification or adapted the harness to accept of more common relay?
Some were just ordering extra relays from lmc.
Or wiring in the normal type relay. I thought someone did a write up.
turbo elk
Vancouver, Wa.
I and one of the guys I work with were talking about this cuz I had one of the relays go bad, and his tour is to pull the pins out of the wiring harness that came from LMC and push them into the plastic connector for the Bosch relays.
Poway, CA
I just bought a couple extra relays from LMC and threw them in the glove box. Knock on wood, I've head the harness installed for a couple years now without any issues.
Mike
Studebaker62
