Lets see ur guages!
Ironman03R
Risingsun, OH (NW OH)
Boost, Pyro and coolant temp on A pillar. Trans temp in dash.
Already had 2 gauges on A pillar and found a mounting cup in the shop so I got creative instead of buying a new A pillar.
subway
be nice to the admin :D
York PA
i hate cutting up dashes, just my personal preference so i got a gage pod and took out my ash tray to put in more. still working on making them all match....
FordGuy100
Silverton, OR
Here is my set up. Tach is on the A-pillar. Then from left to right its boost, pyro, water temp, and oil temp.
boost and pyro on pillar, oil temp there soon
oil water and volts on top.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Three gauge pillar pod and now a single pod over on the dash for the Pyro.
Ironman03R
I had my coolant temp on the steering column like that, but moved it because it was in the way of the fuel gauge. I couldnt move it to the other side cause the shifter is there.
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
Alt, Oil and Temp on the piller.
Boost, Pyro, and Trans Temp on the dash.
hesutton
The Anti-Anderson
Bowling Green, KY
Here are the under the dash gauges. They are the Water Temp, Voltmeter, Fuel Pressure, and Air pressure guages. The amber LED comes on with the Turbo Temp Monitor. The green LED comes on with the fuel pump.
Here is a picture of the A-pillar pod. Not the best shot, but I have the Pyro on top, the boost in the middle, and oil pressure on bottom.
Heath
