Leaf Spring Size?
Ladman
Ladman
plainfield, CT
The leaf spring on my rear drivers side has a broken plate. It is a DRW 4x4. Is there a specific width and size i need to replace the entire thing? I think there is a difference when replacing the calipers with 3" or 3.5". So im wondering if the same applies with the leafs?
howards@howard
Byfield MA
springs
yes The width of the springs is important the number of leafs also but most shops go buy the truck application. you should be able to get the hole stack new cash and carry for $300 ish.
The only exception to that if you carry a lot of weight all the time the have a good shop rebuild both sides together or you will be sorry.
