kitty cat 232b d-v plate leak
Discussion in 'Lounge' started by Thewespaul, Mar 13, 2018.
  1. Thewespaul
    Thewespaul Supporting Member Supporting Member
    4,151
    2,146
    Jul 27, 2015
    Bulverde, Texas
    Gentleman. Working on our shop skid steer today trying to narrow down a delivery valve leak and wanted to hear y’all thoughts. Since we got this machine it has had a bad leak from the top of the IP. Pressure washed it and looks like deliver valves for #1 and #2 are leaking. Easy fix, I pulled up the schematic for this pump and got the appropriate washers and o-rings. Resealed all four and the machine runs like a top now and leaks less but I’m seeing a leak from the delivery valve plates between two d-v. Looks like there is a brass washer in there that can be replaced? The plates are held in by pentagon bolt heads that I don’t have, but I can make a tool for it. Should I do this in the machine or pull the pump and rebuild it while I have it apart? This machine doesn’t get used a ton but it’s needed when it does...
    Here’s where it is leaking:
    8D8C93CE-7B11-41FC-B4E4-4F7F57F4AC67.jpeg C0B69B7F-7472-4788-8C54-AF91BD342FD1.jpeg
Share This Page
