SouthernIDI
Hey everyone if you're near Kingston Tennessee and have an injector line I'm in need of one just blew one on my way back to SC.
They are special. They are high pressure, and if you look into the end, the hole is very small. Each injection isn`t a lot of fuel, butAre the lines special other than being pre-bent. Can you buy steel tubing, bend and fare it?
I have been told (and believe it to be true) the lines if laid straight are the same length but also have to have equal degrees of bends to keep the timing for each fuel line the same.Are the lines special other than being pre-bent. Can you buy steel tubing, bend and fare it?
