david85
Who runs one, and how did you get the high idle to set automatically for cold starting?
I have one installed in my truck, works just fine though I haven't done the high idle part yet, I was planning on using a door lock actuator on the throttle cable in the cab as the actuators are not really rated for high temperature or weather.
I'm also throwing around the idea of making a small microcontroller to interface with the cruise control and feed it a conditioned tach signal and have a line from the remote start tell it to idle the truck up to say 1k rpm. I'd also add other functions to make it a high idle controller like set the park brake and hit the ON button 3 times then hold down the SET button to the desired RPM or something like that.
