Keep custom intercooler pipes from blowing off.
F350camper
BOOST!
If you have custom IC pipes and they keep blowing off, you may want to give this a try. I was talking with some guys about it today, and they asked me to put a video together. I hope it helps someone out. We would all love to have our own bead roller to do this, but this is a great DIY cheap method if you are like me and have more time than money.
https://youtu.be/RSb_qyGvN4U
Nice. I bet your hands are tired but that's a pretty slick idea for cheap.
F350camper
BOOST!
yeah, it takes a bit of work, but gets it done. hairspray helps a lot too.
Yeah bead rollers are in the 130$ range. I was going to go halfsies on one with my buddy because he has piping to do too but this might be a viable option.
F350camper
BOOST!
Yeah, $130 isnt too bad. But you know how it is, a hundred here, a hundred there, pretty soon you are talking about real money! LOL
hmmmm wonder if itll work on stainless.....
may just try it!
thanks for the heads up!
Yeah, boy do I know how it goes. $100 here, hundred there. I've built my entire shop on my little project. Had a few odds and ends when I started. That's a great little idea.
I'm sure it will work on stainless if you have enough grip to squeeze it. Stainless tends to be a little tougher.
F350camper
BOOST!
Its actually not that bad on your hands since it makes such a small dimple in the metal. I also used it when I had to splice two radiator hoses together for plumbing the 4bt to the radiator.
Thats sweet....thanks for this....
..one could weld a 1/4" × 1" x 3" long flat bar to one handle then hold the plier in a vice and it would be much easier even add a spring to between the handles and one hand the deal and rotate pipimg..
Just a thought....
When you are slipping the hose connections over the tube use some cheap hair spray on the connection. This does 2 things. It acts like a lube so it slides on easier. then once the clamp is tight and the hair spray has hardened it acts like a glue holding the hose to the metal tube much better. Really not sure how difficult removal is later on but they will not blow off any longer ...
bike-maker
albany, OR
Awesome idea...I researched this very thing quite a bit when building my Intercooler charge pipes. I too was unwilling to shell out the $$$ for a tool I would probably only use once. This is the first option I've seen for those without welding capabilities.
Here's my version:
Old pair of vice grips, 2" fender washer, and a 2.5" exhaust clamp (2.5" intercooler tubing)
And an example of one of the many beads I made with it.
Doesn't make quite as sharp of a bead as the above version, but no issues thus far after assembling everything dry.
