Just a friendly reminder
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
being that it is coming into the colder seasons, please, go pull your blower motors and make sure the box isn't full of leaves or other dry flammable stuff. almost had a major issue this past weekend in the woods with my buddy Austins truck. he won best work truck at the 2011 rally. cruising down a trail at rausch creek, he stopped and opened his door. smoke billowing out the door. coming out of his vents. got it put out and removed the blower motor to find leaves packed in around the blower motor resistor. smoldering away still. poured water into the heater core and then scooped them all out.
please check your blower motors. it is only 4 little bolts.....
Thats a great idea for those that park under trees. Seen this happen a few times before on this forum. Its called preventative maintenance.
Wicked97
Nebraska
Its always fun when you turn on the defrost and mice start coming out of the dash at 65 mph.
Don't forget your cab drains. Those things clog big time. Simple test... put a garden hose in your cowl vent. the same amount of water should come out at the same speed it's going in.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
If the leaves start on fire in the heater box, put the blower motor on HIGH - fire will go out quicker............
Read my signature before taking my advice..... ;)
PlumberPoopyHands
