HammerDown
I just messed with it again...everything is seated etc but the top/right turn signal hook does not grab as should. Now if I remove the little centering leaf - spring then at times it barely hangs on.I just replaced my turn signal switch with that same part. Make sure the screw at the 9 o clock position is turned down and the two light blue wires have clearance from the back of the wheel. After installing it I kept burning a fuse and didn't realize that the assembly was sticking out a few mm too far forward. The wheel and unbundling takes the longest but it's an otherwise straightforward task.
I've wasted too much time messing with it and ordered the entire switch from Rock Auto.
However, I'll be a little more that disappointed if the new unit (right hook) barely grabs too.
