issues
whatsup
CO
So my little 300D just shot a radiator....which I figured would happen because I could see moisture on the fins. But then I had a hard time starting it. I was turning it over and didnt see any smoke. So I figured it lost its fuel prime. Finally I could see smoke, then it started. But as I let it warm up I looked underneath it and fuel was leaking. So I looked for the culprit and see fuel is leaking out the injector pump....At every injector line. So I am assuming either the fuel filter was plugged up or running tranny fluid screwed up the o-rings. Anyone else have this issue? What is the solution for keeping it from happening again?
Thanks,
jeff
69dieselfreak
well that nice
rimrock arizona
ok first how do you see moisture in the radiator shouldnt the thing have some sort of coolan in the thing
and your fuel leak should just be your return lins on the injectors
