issues with wait to start and glow plugs
jfp3205
new ford 7.3 owner
mt pleasant, SC
Good afternoon,
I am sure this has been answered and I think I asked it once before but this is driving me crazy.
Long story short, truck would take forever to start and i decided after i checked all the glow plugs and saw they were good, it must be the relay or god forbid the ip pump going bad.
I took the truck to the ford dealership and had the shop maganger look at it. When you turn the key on, you heard several clicks and the volt meter would drop and i thought this was normal. The shop guy said this was not normal due to it being to warm out side for the glow plugs to have to cycle on an doff like that.
After all said and done, they replaced the entire glow plug harnesses going into the controller and after that, the clicking was never there and the truck fired on the first turn. Life was great.
Yesterday, i went to start the truck. The WTS light came on and right off again and the relay was clicking. the truck would not start until i cycled the key twice and it finally statred. Once it is warm, it starts all the time.
My Question, Is my glow plug relay going bad or is possible the glow plugs again and how long are they suppose to last? It seems like I am always changing them and I have been using Bocsh due to the horror stories of cheap gps
Thanks for any advice
The dealership guy was wrong, these trucks always need a little glowplug help on the first start of the day. After that, you don't need the glowplugs unless it sits for a long time, but the factory controller will still cycle them some.
Why not move over to the dark side and go to a manual pushbutton switch. You will never look back, and kick yourself for all the money you have spent trying to get the factory controller to work.
A good comparison is the pushbutton 4x4 system versus the good old transfer case shifter sticking out of the floor and manual hubs. Which one would you rather have and more importantly, which one can you depend on when you really need it?
sle2115
NRA LIFE MEMBER
Southeast Ohio
Sounds to me like bad glow plugs. The system senses voltage and if a single glow plug goes south, it can cause short cycling. You might want to try a set of Beru plugs and see how they work. I wouldn't trade you my solid state system for 10 manual buttons though, mine is about 10 years old, as are the glow plugs and it starts in any Ohio weather. It does however cycle EVERYTIME it is started, the length of the cycle changes, but it always cycles. The guy at the dealership is full of himself in my opinion. My relay/controller was bad when I got my truck, I put one on and it's worked ever since. The solid state system isn't like the old water temp sensor system that failed quite often and many times failed in the ON cycle, causing glow plugs to overheat and such. Check the glow plugs or just replace with Beru and be done with it.
JunkCowboy
