you have some serious work ahead of you then. most modern PTO systems are hydraulic and is rearward facing. your first obstacle you will run into on a forward facing system on the driver's side with chain drive is the trans bell housing and the hydraulic slave cylinder. on the passenger side you will have the starter to deal with.
Has to be pass side, so I'm guessing the best option is the Tcase and then I can decrease the angle and make a better system.
