Is this a boost leak?
94250turbo
Detroit
I have the 3" rear turbo housing so the downpipe just slides in and then there is one bolt on the manifold that holds it in place. Anyway when the truck is idling i can feel a little exhaust coming out where the DP meets the rear housing.
If this area that you feel the gas escaping is past the turbo it not something thats called a boost leak. Reason is its already gone thru the turbo and used itself up spinning the turbo. So its an exhaust leak. Sealing it up wont make the truck run better nor build more boost. It might be cleaner but might sound better but thats all.
MechDiesel
