Sidewinded_idi
if you've been following my progress you would see I had the ford Black Death happen when my compressor blew up. I installed a new compressor, flushed the system and installed a new orifice tube (blue) and accumulator/drier. Being a 92 I had r12, instead I used 9 oz of water oil and mixed my own 70/30 blend of propane/ isobutane. My question is because on the freeway or when running I have to keep the fan speed on maximum to keep the condenser clear of freeze. I've never had it happen yet but I assume at my vent temps it's very possible.
Is there any way to theoretically raise the output temp to30 degree range? System isn't under or overfilled it's just working really good. My suction line actually keeps the compressor cold! This pic is with 82 degree ambient temp going 65, at idle it'll raise to about 18-20 degrees
