Is a Road Draft Tube calling my name?
wildman7798
Great Pacific NW
So I am getting ready to put the old girl back together tomorrow 86 6.9 and since I took the entire Gen 1 Banks stuff off (less turbo and exhaust) to get to all the return lines and generally make the GP and O ring return line stuff easier. I noticed that from the crankcase vent (off the oil filler neck) to the depression valve some pretty decent amount of oil in the hose. Then in the air inlet of the turbo more oil on the floor of the hose and turbo inlet. When I removed the pressure hose to the intake head the floor of the turbo outlet had some puddling as did the pressure hose, the floor of the cast intake head is pretty wet above the screen on the intake, the intake screen was pretty wet and the floor of the intake looks like it is pretty well fogged with oil, not puddled but moist. This is a 90k truck that sat for 9 years, I drove it about 2 miles and ran it about 30 minutes before tearing into it. I have not even changed the oil yet. Is this a normal amount of crankcase pressure run off and blow by. My understanding is these engines are prone to this to some degree. If this was a gas engine I would be very concerned. I find it a little ironic that some guys go to road draft tubes while other guys are trying to burn waste oil. Any real benefits to plugging off or removing the anti-depression valve and going road draft? I almost think running this engine a while and getting some heat in it might clear some of this up, perhaps it's normal? Anything else I should look for before I put this all back together? The road draft tube might be kind of a novelty, is it any more than that? Wildman
Black dawg
USA
pretty normal, especially with boost. RDT doesnt work out well with these trucks, they just have too much blowby. After you get it back together, take it for a drive, then pull the hose from the filler neck. you will see what I mean. I have tried RDT on everyone of these trucks that I have owned, and just couldnt deal with the amount of smoke and smell that came out.
bleachasaurus
