Ip timming/gauge compression
larson
Springtown,texas
The blowby looks fine. Not that much at all from what the video shows.
run the **** out of that thing. It sounds fine also.
adriantkt
Tecate California
79jasper: i have some glow plugs around here and do an adapter
larson:
Yeah i will keep running this engine till it's completely worn out, feels strong
but the blue smoke drives me crazy, its an small amount idk if its normal in this trucks?
larson
Springtown,texas
The question is once it's been tested in every witch way and something doesn't seem to spec are you really going to rebuild the motor?
adriantkt
Tecate California
No, maybe swap in another motor an IDIT or save for some cummins swap depends how much i save till this motor is out
riphip
Memphis, TN.
Is an oil burner, gonna smoke some. Keeps mosquito population down especially after adding tranny fluid
Rick
C_Luft
Vancouver, WA
Your engine is fine, every once in a while a seal will go out, no need to replace the engine just because one seal started leaking. Now this is my old engine, it was really worn out it leaked/burned 2 gallons of oil in 250 miles, it has 2-3 cylinders worn out.
https://youtu.be/VAggOk5ID_A
pwillis
