BrianX128
I've had a drip here and there from the old 7.3, I was initially expecting it to be valve cover on the passenger side or possibly oil pan seeping. Turns out, I don't know what it is.
First this random bolt isnt in if you look between the alternator and water pump. I had the entire front of this engine off 7 years ago. I'm half scared to put that bolt in further.
I'm also questioning if the IP front cover where you take the allen key bolts out has a gasket? I put a new pump on this 7 years ago and may have just put it back on. I'm gonna take it off and re-rtv it but with how much oil is on top of my water pump I think that's what is seeping [right above the water pump]
