Interesting hydraulic pump bracket
Jake_IN
West Lafayette IN
I've never seen one of these hydraulic pump brackets before. Is this just a really well done home made job or did a company actually sell these? If i had the money i'd pick it up for the sole reason of just to have. Which side of the engine would this mount on?
http://chicago.craigslist.org/chc/pts/3149155586.html
Hi I have a hydraulic pump in bracket for central hydraulics the pump and the bracket fit a 1989-1993 7.3 diesel engine this pump will work for tow trucks dump trucks anything that uses hydraulics it also has a new clutch I bought the bracket new for $800 in the clutch cost 300
500$ obo asap please no lowballing taking up space if you have questions please e-mail me you must put your phone number or i will not respond due to all the spam
FORDF250HDXLT
Maine & Oklahoma
if someone comes across one of these again,shoot me a pm if ya wouldn't mind.;Sweet
don't worry about pulley type,im sure that could be swapped out easy enough to serp.
mblaney
Ottawa/Ont/Canada
I have a pump similar to that (salvaged off an F350 I scrapped); it was mounted lower on the passenger side and used a dedicated v-belt. There was a v-belt pulley mounted on the end of the crank shaft (that I did not salvage) for the pump. I am guessing that the loose pulley in the pic is supposed to be crank mounted the same way?
The pump bracket I have is very simple, I can take a picture of it if you like.
Ahem...ya that aluminum loose pulley mounts to the crank, there was a setup for sale while ago here IIRC and I picked it up for a friend...
Good deal...may end up with myself yet...LOL
Be nice for PTO winch !
mblaney
Ottawa/Ont/Canada
Here's some pics of the one I have. It uses the alternator bracket bolts
you're better off with a PTO off the trans you're putting in. clutch pump PTO's are a weak second to a trans mounted PTO.
hce
So can i....
Glasgow MT (Official middle of nowhere)
Most the manufactures of hydraulic bale beds for round bales make hydraulic pump brackets for electric clutch hydraulic pumps. They are mounted on the engine vs the trans as it would be a nightmare to operate a pto operated pump on a manual transmission for the bale bed. Most of the time the clutch is pushed in when grabbing a round bale.
RANDY-EL
ST. LOUIS, MISSOURI
RANDY-EL
ST. LOUIS, MISSOURI
