HS108
Diesel Newb
The alternative is a stainless flex line which Mel will be happy to sell you.
How much does he want for this, couldn't find it on his website?
The actual injection pump inlet spec is SAE #5 O-Ring Boss. Which is a 5/16" fitting, having 1/2-20 threads. I just ordered some #5 ORB x 1/4 FNPT to get rid of the hard feed line and associated olives.
What will you be using for line between the filter head and IP? Thinking about doing this since I have to crack the system again for the FSV and electric pump install...even though I won my first battle with the olives today (motivation).
The clear hose name you probably are looking for is Tygon tubing. It virtually last forever.
Didn't there used to be a trick using a med bottle?Sometimes installing injector o rings can be a real pain. Too bad we don't have a tool make so the rings can slide down over it to the grooves.
At least the top of your engine is clean/dry! Must say I'm jealous. Mine was oil/fuel soaked with a layer of nature on it before I touched it![]()
