6.9poweredscout
Bleeds IH red...
I don't see why you couldn't have a machine shop make up some solid steel pushrods than have the ends teflon coated for less resistance....?
-Jon
-Jon
-Jon
"Solid steel" is weaker than hollow tube. Second, how do you expect to lube the upper valve train? Hollow is a must.
If you get an accurate measurement of the length, Jesel can make a set of chromolies.
Got the wheels turning now. Does anyone have a stock 460 pedestal mount rocker to compare side by side with a IDI rocker arm? On a 460, changing to studs and roller rocker arms is supposedly worth almost 25 horsepower. It would be less on an IDI due to better geometry between the valves and pushrods, but it would definitely free up a little horsepower. Even if the rockers for a 460 don't work, there's probably one out there that would. This also opens up the option of increasing the rocker arm's ratio which increases valve lift for more power (providing there's enough valve to piston clearance).
