From my IH manual
.................................................................................Nm......lbf-ft
Air Cleaner stud Adapter(see note 1).................................61.......45
Camshaft Screw............................................................20........15
Connecting Rod Nut(see note2)........................................69........51
Crankshaft Vibration Damper Bolt.....................................122.......90
Cylinder Head Bolt(see note 3)(used)................................108......80
Cylinder Head Bolt(see note 3)(new).................................101......75
Exhaust Manifold Bolt(with lock tabs)(see note 4)................41......30
Exhaust Manifold Bolt(with metal prevailing bolt)(see note 4)..47......35
Flywheel mounting bolt(see note 1)...................................64.......47
Front Engine mounting bolt..............................................95.......70
Glow Plug.....................................................................16.......12
Injection Pump Gear Cover(see note 1)..............................19.......14
Injection Pump Gear Mounting Bolt....................................34.......25
Injection Nozzle.............................................................47.......35
Intake Manifold Bolt(see note 5).......................................33.......24
Intake Manifold Gasket Drain Plug......................................54.......40
Main Bearing Cap Bolt(see note 6)....................................129.......95
Nut,Injection Pipe...........................................................30.......22
Oil Pan Drain Plug............................................................37.......28
Valve Cover Screw(See note 7)..........................................8........6
Water Pump Mounting Bolt(see note 9)...............................19.......14
Water Outlet Elbow Mounting Bolt......................................27.......20
*Unless otherwise specified, torque values are with threads and washer faces coated with clean engine oil.
Note 1-Apply general purpose Lock N' Seal (IH P/N 577 588 C1) to all threads of bolts prior to assembly.
Note 2-Tighten bolt connecting rod nuts to 51 Nm (38 lbf-ft) before final torque is applied.
Note 3-Cylinder head bolts to be torqued in steps as specified in Figure 3. Final Torque value for new and used bolts is different.
Note 4-Apply "Never Seez" compound (IH P/N 634 227 C1) to threads of bolts prior to assembly, then torque in steps as specified in Figure 6.
Note 5-Intake manifold bolts to be torqued in steps as specified in Figure 6
Note 6-Tighten four main bearing cap bolts to 102 Nm (75 lbf-ft) before final torque is applied.
Note 7-Valve Cover screws to be torqued in sequences as specified in Figure 4.
Note 8-Rotate Engine until timing mark (notch) on vibration damper is approximately 20 degrees before vertical position as viewed from the front of the engine, approximately 11:00, Refer to Figure 8 Tighten each pair of bolts down evenly. Refer to Figure 9
Note 9-Clean bolts thoroughly. Apply liquid gasket (IH P/N 446 839 C1) to designated bolts(refer to figure 7) only
Would probably help if I had the pictures to go along with it
