Idi Glow plug controller operation?
DirtyWood
Over the Hills and Far Away
As far as the WTS light not working, occasionally my WTS light does not work but I'm pretty sure it's a loose connection behind the dash. More important than the WTS light is whether or not the voltmeter moves when you engage the glow plugs. Voltmeter should swing all the way to the left and then twitch for a few seconds after the initial cycle finishes.
VanGo
Michigan
“With key on you should see battery voltage on both large studs of the solenoid”
This is what has not been happening…
I think I am going to purchase another controller. There is nothing showing that there is any power to glow plugs. I was also able to wire up a bulb to the wait to start light.
Everything is getting power to where it should on controller yet there is nothing to the glow plugs.
The constant hot post, the ignition when on is hot and the wire in the harness that plugs into the wait to start all get hot with the key on.
No clicking, and nothing happens.
If I jump the two large posts the plugs warm up and the vehicle starts right up.
I also would think that if I pull off a glow plug wire or two and try to start to glow plug controller would sense that it is not getting the correct reading and should click as folks say happens when a glowplug or wire is bad?
ihc1470
Idaho
How about the ground wire what are you seeing there? Have you tested the solenoid by itself? It is possible the controller is good but solenoid is bad. They can be replaced seperately.
VanGo
Michigan
I have not checked the solenoid by itself. I really want to get the vehicle working as it should. Afterwards I will check and purchase a solenoid in an attempt to change and have a working spare.
Thank you,
Ed
ihc1470
Idaho
The controller switches the ground to the solenoid. If I was testing the system I would lift the small white wire free from the solenoid then ground the small terminal with a jumper. You are doing what the controller would normally do. Key on the solenoid should click and you should have power going to the glow plugs. If this test normal than either the ground is not good to the controller or the controller is bad. If you do not get the solenoid to click than I would assume it is bad since you have stated you have power to the small red wire connected to the solenoid.
This is a good explaniation of what is going on in the system.
VanGo
Michigan
Ok now that I just replaced the steering pump I will try to get this glow plug thing resolved. And then investigate air intrusions ☹️
If these items are wrapped up I may be good for a while!
VanGo
Michigan
A sign of progress today. As soon as I got home I ran out and put the new controller on. While I was at it I added an additional ground. I gave it a try and I seen the wait to start light come on and when it went off I turned the key and it started right up.
In reading I seen people switch over to a heavy duty industrial solenoid. I was wondering if anyone has done that along with the solid state unit? Keeping the stock type setup but replacing the portion that I have read that usually goes bad on these controllers.
Also just curious if anyone has bought a glow plug controller at Oreilly’s? It actually comes with a lifetime warranty… I had to double check because I never heard of an electronic part having a lifetime warranty. I don’t like the fact that these chinese parts go bad often however if the warranty holds up. At least I don’t have to keep buying them. I plan to get another solenoid and seeing which of these units I can salvage.
I was just wondering if I should make a setup with the industrial solenoid
ihc1470
Idaho
I believe the controller on my truck is OEM. For a little while until I got a good grasp on how the system worked I had a wire run inside so I could control the ground and get things started. Did not even have a switch just the wire that I grounded for starting. I bought a controller from Oreilly's and tried it with no change. I was getting rapid short cycling. They were nice enough to take it back which did surprise me as most electrical stuff you can not return. Anyway I just knew the glow plugs were good as I had just installed them and had tested with a Fluke meter before they went in. They were marked Motorcraft on the package and the etching on the plugs looked correct. That is when I learned about China junk.
Leasons learned for me were even with a good ohm meter you are not getting the true story. Measuring less than an ohm resistance can be tricky. Reason I recommend doing an amp draw test so you really know what is going on. Be carefull where you buy you parts. I did get my second set of plugs from Oreilly's and they have be fine. From Ford parts they were only about $5.00 more a plug. When I need another set I probably will get directly from Ford.
So to answer your question I would test your old parts and determine what failed. If the electronics failed and solenoid test good I probably would pull the solenoid and put it someplace that I can not find in five years when I need it! However I probably would not run out and buy a controller just to lose it on a shelf when I needed it down the road. Easy enough to run a wire to get things started if needed and you do not even need a switch.
But that is just me. If I was looking for just a spare I probably would just pull one at a pick and pull as they are easy enough to test. I think the quality of a used OEM controller probably will be better than most of the new stuff you will find out there.
If you feel better having a new controller on hand than go for it. Only you can answer that question for yourself. Glad you are getting it worked out, always a nice way to end the day.
DaveBen
Ukiah, Ca
One might want to use Motorcraft glow plugs only. Too many fake glow plugs going around under "other" names. Just Chineese junk. Motorcraft glow plugs in the Motorcraft plastic bags are hard to fake.
ihc1470
Idaho
The fake ones I got off EBay said Motorcraft, should have known better. About the only thing that was different between them and the originals was they did not have the small hole punched in the plastic bag. Seems like there was one other very suttle difference, maybe the crimp at the top. Been to long now. Anyway the real difference the fakes pulled 10 amps while the OEM pulled around 22. The controller saw that as glow plugs that were at the end of the heating cycle. They would of worked if I wanted a manual switch system and I did use them that way for about a week until I got the correct plugs. However I like the OP wanted a system that functioned as designed.
VanGo
Michigan
I typically will do a bit more research than average. Early on I did read about the fake glow plugs etc… also read and watched quite a bit about the constant clicking from the controller as not being a good thing.
Here is a little bit of my experience with this van so far. As soon as the engine was put in all new electrical items to start fresh. Purchase motorcraft parts directly from Ford and a new nice glowplug harness from recommendations on this site.
When we first attempted to start once primed it fired right up. (But the wait to start light module had a bad bulb so I never could see what was happening) I still had work to do but it would sit for a week or so and whenever I came to work on it, she started instantly. Just as I was hoping, from the new wiring and electronic lift pump updates.
One day the key was left in the on position for quite some time. Afterwards it was a bit more difficult to start. I had suspicions after reading about how fragile the solenoids are. And I realized that I could have caused an issue by running a direct larger wire with no fuses. (That was not a good thing to do as I continued to read)
My diagnostic checks based on where power was flowing convinced me the controller is not working as it should.
I never owned a diesel and the friend of mine that has allowed me to bring into his shop owns a few powerstrokes. I am seeing that this is a different animal despite both being 7.3 engines.
Not knowing if glow plug should kick on even for a second or two when temps are already warm.
My thought and you guys can correct me if I am wrong. I suspect that the solenoid was screwed up by leaving the key on for such a long time and not having a fuse in?
Maybe I am wrong but, I know something happened because it started fine every time.
I wanted to get this squared away before I started digging into the fuel system again.
As mentioned I changed the large wire to reassemble OEM with fused links. There were already Two old low plug controllers in the van and I had the new one that I purchased that I may have screwed up.
Now I am happy because at least I am seeing how the system should work.
However with all that said I believe I am going to change the fuel line after the lift pump so that it is continuous and put a check valve at the feed to the lift pump.
I want this vehicle to start right up When using the correct starting procedure.
DirtyWood
As I understand it leaving the key "on" can also burn out the Fuel Shutoff Solenoid due to overheating. I'm not saying you should give up on the factory controller but the manual glow plug setup eliminates some problems and overall is more likely to get the engine started easily than the OEM controller at this point. The Stancor/White-Rodgers solenoid is an upgrade for both the powerstroke and the IDI--truly massive solenoid.
VanGo
Michigan
Thanks for the info on the fuel shutoff solenoid. Is there a fuse associated with that, would also be nice to know :)
Things appear to be working however I may consider the better solenoid in the future as I continue with this van.
VanGo
Michigan
Is this the one you are referring to?
White Rodgers 70-111224 Solenoid, SPNO, 12 VDC Isolated Coil, Continuous Duty, Normally Open Continuous Contact Rating 80 Amps​
Or …
Solenoid, SPNO, 12 VDC Isolated Coil, Normally Open Continuous Contact Rating 200 Amps, Inrush 600 Amps​
bneumann22
