LCAM-01XA
Sounds about right actually. Tho if quality is anything like their throttle cables I wouldn't touch it w/ a 20-foot pole. jm2c
Wyreth, exactly man. Way simple ways of doing stuff. I don't know what they call them, but the twist cable with the red release button in the middle would be perfect.
What'd be cool is something referenced to said accessory, lets say an air comp, so that once a preset pressure is reached, it'll kick down to normal idle. Then when the pressure drops, it'll kick back up.
Thanks man. I've spent a lot of time (and money) getting it there...im really jelous of your lights matrix
I had thought about the door lock actuator before but was told they would burn up in short order since they're not rated for continuous duty.I didn't want to spurt out anything, because I haven't done any testing yet. But we have plenty of actuators available to make a better high idle solenoid.
Numero uno: idle air control valve from a gasser. Usually have four wires, can also be setup to be adjustable from in cab.
Die zwei: a door lock actuator. Would give a good size jump in idle, but non adjustable.
Plenty of other stepper type motors to be used.
Just gotta know your electrical components.
I would be interested in such a kit. But i would also want the option to keep the idle high for jump starting or live hydraulics...I wander if anyone would be interested in such a "kit" to do so.
Or at least the components (minus wire) with detailed instructions. I have a LOT of free time and a LKQ about 15 miles away.
At least we sorta have the ball rolling now.
Could an electric cruise control controller from a '93-? Ford work? Maybe use a headlight switch. The rheostat could be used to inplace of a speed sensor to control idle speed? The two postition poll portion could be for OBA if someone has that setup. Just spitballing here.
