I think my fuel selector switch is bad.. need help
ah1988ford
florida
I decided to take the truck to school today and I made it about 10miles down the road and I hit a bump and the truck surged and then almost died. I though weird and kept going, about a 1/4 further it started to chugg like it was running out of fuel and then it died. I poped the hood and turned on the electric fuel pump and I couldnt get any fuel to come out of the filter head. I thought my electric fuel pump was going out. So I thought mabey the shower head in the tank broke off because I was below a 1/4 tank, so I switched tanks. I started to get fuel and bled the air out and it fired up. About 1-2miles down the road the truck startred to chugg again and it died. I pulled off to the side and was getting no fuel out of the filter head, while the switch was swithced to the 3/4 tank of fuel. I then started to crank bleed and prime and was getting no fuel, so I switched back to the tank ( the less than 1/4 full tank) and I started to get fuel and bled the air out and the truck fired over. I tried to race home and the truck dies about a mile away from home. I switch the fuel secector valve agin and it dosent change tanks this time, so I turned the electric fuel pump on again and no fuel was coming out of the filter head. I switched the switch back and forth several times and It finally swtched to the tank that was 3/4, but I was not able to get any fuel to come out of the fuel filter head. So I go a tow home and it is in the drive way.
Does this sound like a bad selector valve? Is there a way to test it? I have read where people just put manual ball valves in place of the selector valve. I would like to put manual valves in, but would I then be able to tell how much fuel is in my tank if I remove the selector valve unit?
Yes its the switch. Get under the truck and bypass the switch. What I'm saying is to remove the feed line to the switch from either tank and just add some rubber hoes to bypass the switch. The supply line is 3/8 and the return line is 5/16. Both lines needs to be bypassed to a tank. Remove the fuel tank changeover valve and open it up. You probably will find broken pieces of the tank shower heads in there. But bypassing that valve keeps you driving till its fixed.
ah1988ford
florida
Thanks, I will definetly do that, I hope the shower head isnt broken, I guess we will see.
When I go to bypass the switch will I be able to get a reading from the sender in the tank to tell me how much fuel I have 1/4, 12/, 3/4 ect. I am pretty sure I can install manual valves in place of the selector switch. I just dont know if my tank guage will be able to tell me how much fuel I have in the tank if I remove the selector valve. I dont know if the dash guage
gets it reading through that valve throught the fuel sender or not. If that makes sense....
Yes you will be able to tell what the level is in the tank you choose to run on. You probably should plug the lines from the other tank just to make sure they wont leak fuel thru the now disabled tank selector switch valve. That does not mean you can't still switch back and forth between the tanks. It just means you will only be able to draw off the one dedicated tank you choose to run.
ah1988ford
florida
Thank you, I understand now.
I will be sure to take pics and post them.
I am not sure how you are going to read the level in the tanks if the selector valve is not working/moving. It does electrically select the proper sending unit and puts that sending unit to the fuel gauge up front.
You can try it, and if it works great. If it doesn't, or you want to take the old valve out all together when you go to manual valves, you just need to add a switch somewhere to switch the sending units. If you mount your manual plumbing valves in the floorboard, you might want to get a little plastic box from radio shack and mount a switch down there also. You will need a single pole, double throw switch, one with 3 terminals and two positions.
The center terminal is where the yellow/white wire will go. This is the wire going up front to the gauge. The darkblue/yellow will go to one of the other terminals, this is the front sending unit wire. The yellow/lightblue wire will go to the other terminal, that is the wire coming from the rear sending unit. You can spin the switch around or swap the front and rear wires after you get it going, so moving the switch to the front will be the front tank, and moving it to the rear will be the rear tank.
ah1988ford
florida
Thanks, I was trying to find a post like that! I will get pics and document what I did, when I get around to it.
I didnt want to just replace the switch because I am afraid it will just plug up or malfunction again. I would rather plug up my fuel filter than that valve, a fuel filter is easy to replace over the road. My plan is to do the manual bypass valves for now and install the selecor valve later. So I will replace the selecor valve, but I will then have the ability to bypass it if I need to. Righ now that truck is a secondary backup vehicle, so I just need it to run.
madpogue
Madison, WI USA
If you go manual, just keep the existing selector and switch in place. With the manual valves, the old selector won't do anything fuel-wise. But the sending unit switching functionality is strictly an electrical switch (no mechanical action), and it sounds like that's still working (the gauge responds properly when you switch, right?). So the existing switch will still switch sending units and your gauge will continue to work properly on both tanks, provided you throw the switch along with doing the manual valve action.
(Or, as suggested above, just replace the whole selector assembly....)
From what I understand, there is mechanical action to electrically change the sending units. The selector valve has a little motor in it, and while it slides the spool in the valve, it also spins a section that has electrical contacts that select the correct sending unit.
madpogue
Madison, WI USA
^^^^ Confirmed - EVTM shows that the flipping of the sending unit contacts is mechanically activated by the motor that opens/closes the valves. Still, if that part of the selector works, even if the valving has failed, the OP could continue to use it.
fsmyth
conroe, tx
Also confirmed. The motor in the valve also drives the tank gauge selector.
I took mine completely apart just to find out that the motor wasn't blowing the fuse - It was a worn out dash switch (shorting).
I did put some of the el cheapo in-line clear plastic filters on both suction lines (just to catch crap coming to the valve).
Also good for a visual indicator. Since I intend to run WMO in this truck, I added:
10-micon frame-mounted filter after the valve.
5 PSI electric fuel pump.
2-micron filter after the pump.
Left the stock filter in.
Fuel pressure gauge after the stock filter (IP inlet).
Right now, the electric pump is feeding the mechanical pump (I know, I know. No problems so far).
All the rest stock.
Take it off, clean it good, blow it out, exercise it on the bench, and use it. If you can hear the motor, chances are that
it will work. If you have it off (on the bench), it is very easy to tell if the ports are working.
<als>
If you need the pinout on the valve, or switch wiring, let me know.
Sgtbyersfw
