slam1, that sounds normal for a stock truck and in your conditions.
funnyman06, the white part of that is a little concerning, possible timing related, does it run any different when its cold and the idle kicks up? I guessing your pushing on the diesel pedal pretty hard when you see the smoke. The easiest way to get rid of the smoke would be to not push so ******* the diesel pedal. Your next option would be to take it to a shop and have it timed or try playing with it yourself. Also look around for other problems, fuel leaks on top of the motor and anything else that doesn't look right. If you want the power you get with the diesel pedal to the floor you could turbo it.
