I have low WOT Voltage at FIPL
Junkyardslug
Raleigh
Greetings all, first post. I have a 1993 E-350 bus with a 7.3 / E4OD
The OD light started flashing, I pulled the codes that included 23, I don't know how old the FIPL is but I figure as long as I am adjusting it I should throw on a new sensor just to be safe. The new Sensor is from Napa if that matters. I do have 5V going into the sensor at the harness
well, I can adjust the closed throttle voltage from about .65 to 1.65 BUT WOT seems to be between 3.6V and 3.8V no matter what I do.
I have tried at .95V, 1.00V, 1.10V, 1.15V, 1.20V at idle (engine warm, idle solenoid off). The OD light is still on and no matter where I set the idle voltage the motor revs high before shifting and the shifts is very soft.
thanks all
George
PS: I searched, there are a lot of FIPL posts, I know this must have been addressed before, I couldn't find this particular problem
PPS: Don't let those Torx bits strip out your bolts that hold the bracket on, I had to pull the IP pump to get that stinking bolt out. NOT FUN ON A VAN CHASSIE!
FORDF250HDXLT
Maine & Oklahoma
keep trying.it can be a pain but you'll get close to 1.2 idle / 4.0 and above at the same once you find the correct axis.its tricky but worth the time spent.
was 23 your only code? did you hold WOT during the scan?
Welcome to the forum. When you installed the tps did you install it the correct way on the drive tab on the end of the throttle shaft. Lok at the old on for the marks made in it. We really don't have any control over the wot voltage. We just have the control over the idle engine off warmed up voltage. I prefer 1.24 volts. You need to pick up the voltage on the center green wire on the plug to the tps. No need checking the other wire voltages.
Junkyardslug
Raleigh
Thanks Gents,
I rechecked (with the Engine warm and throttle held down for the KOEO test)
Still pulled Code 23 [flashed code twice] and then one single flash and then code 14 [flashed code twice]
I can't get the FIPL to go over 3.8V (and that is idle at 1.65). If I adjust idle Voltage down the WOT voltage goes down also, can't seem to get the voltage span opened up any
Junkyardslug
Raleigh
Just went outside with my DVOM, no continuance between pins on RPM sensor, no Voltage out while running. The wires going into the sensor were bare also. Going to pop off the belt & vac pump and get the sensor changed, hopefully that will take care of that code. Thanks for all the help, I'll report back the findings
Wel thats a nice update telling us your tach has not been working. No matter what. The tach must work for the E4OD to operate properly. Actually there are a few more electrical signals the trans needs to see to shift correctly too. But change the tach sender first. Then work from there. I'm surprised nobody asked if the tach was working. Had any of us been there with you looking at the truck we would have seen that right away and helped you quicker. We need info to offer repair info but its going the right direction now.
Junkyardslug
Raleigh
I don't have a Tach, it's a Van Chassis. I'm swinging by the Ford Dealership first thing in the AM to pick up a new sensor
bneumann22
