I DROPPED THE BALL!
while putting the t-stat back into the block,
I turned around th grab the ratchet, and knocked the damn housing off the block...
now the check ball is MIA!
anyone know the size of the bearing?
after an hour of cleaning and searching, im throwing in the towel.
Clb
Another old truck
nannyfornia
Fwiw
Th 88 had none! The 2 ford tech guys I asked said it will be fine.
It just bleeds the air faster ( I think) !
If ya got to brop a ball thats a good size ( tiny).
jaluhn83
Upper Marlboro, MD
Just take it down to the hardware store and find one that fits. Somewhere around 1/4" IIRC. Just needs to be a bit smaller than the hole to move freely.
My experience running without one is that it will double to triple the time it takes to warm up and will get cool (140-160) at idle or under light load. Just that small amount of flow is enough to dump a fair bit of heat I guess.
BrandonMag
Dana 50 rebuilder
Oregon east
I replaced the thermostat in my '89 a couple of years ago and lost the check ball. I figured it was so small it wouldn't make any difference. This is EXACTLY the same experience I've had. It takes FOREVER to sorta warm up... actually, it doesn't warm up at all unless I'm hauling something heavy.
I don't know what size it is, but finding this out makes me wanna find a ball the correct size, rip mine back apart and install the damn thing so it operates at the correct temperature.
I know it seems frowned upon, but what if someone just blocked the hole?
Or ran a hotter tstat?
Sadly there are no hotter thermostats made for our idi engine. Now I realize we can buy other after market thermostats but they are not correct and can't pass enough coolant to keep a idi engine running cool when hauling.
OldIron82
Northampton PA
What a wonderful coincidence! I was going to make a thread about this tonight anyway. The woman was insistent on helping me today so I told her she could clean the two coolant pipes, and scrape the old hardened gasket material off. The upper one (thermostat housing) she was working on while I was running a tap down the block in preparation for studding and she asks " what is this, a ball bearing" and I go "HUH!?" "This ball, is it a ball bearing?" Woman, a ball bearing is a ball bearing WTH you talking about? "There is a ball in this pipe" No dear, there is no ball I don't know what in God's name you are talking about but there is no ball. "There is a round ball I see inside this thing" Well now I'm annoyed this conversation was going on for at least two minutes so I stopped what I was doing walked over and to my absolute disbelief, a ball!!! She had this I told ya look on her face and I'm suuuuuuure I'm not going to hear the end of this for a few moon cycles but anyway...
The ball is inside the thermostat housing and it's held in there by some hard material but it's not cast iron. Perhaps just old gasket material? Should I try and dig it out? My question I was going to make a thread about is "Is that ball supposed to come out"? I'm guessing the corresponding hole in the block is smaller than the ball and the block is what the ball is supposed to engage as a check valve?
If someone gets back to me tonight before bed that it indeed should be able to come out of the housing I'll gladly dig it out quick and throw the micrometer on it and get a measurement.
OI82
pwillis
